IoT Hub Message routing - $body not working
TITAN 46 Reputation points
2022-10-25T14:21:46.647+00:00
I have an IoT hub device which sends messages via message routing to a bus queue and then to a logic app (which sends email alerts).
When the message routing - routing query is set to:
true
I get email notifications.
when i set it to:
$body.sensor_data.thermocouple_temperature > 0
example message from the device:
"nodeId": 0,
"firmware": 6,
"battery": "3.29",
"battery_percent": "99.64",
"counter": 64,
"sensor_type": 50,
"sensor_data": {
"rms_x": 1.69,
"rms_y": 1.93,
"rms_z": 8.5,
"max_x": 10.98,
"max_y": 10.98,
"max_z": 12.44,
"min_x": -12.44,
"min_y": -15.37,
"min_z": -186.66,
"vibration_temperature": 27,
"thermocouple_temperature": 25.75,
"current": 0
"sensor_name": "EXAMPLE",
"type": "sensor_data",
"addr": "EXAMPLE",
"received": 1666689894382,
"original": {
"mac": "EXAMPLE",
"receive_options": {
"ack": 0,
"broadcast": 0,
"type": ""
"data": [
'EXAMPLE',
'EXAMPLE',
"type": "receive_packet"
"EventProcessedUtcTime": "2022-10-25T10:30:43.3605566Z",
"PartitionId": 1,
"EventEnqueuedUtcTime": "2022-10-25T09:24:54.5080000Z",
"IoTHub": {
"MessageId": null,
"CorrelationId": null,
"ConnectionDeviceId": "EXAMPLE",
"ConnectionDeviceGenerationId": "EXAMPLENum",
"EnqueuedTime": "2022-10-25T09:24:54.4300000Z"
"nodeId": 0,
for example, it doesn't send emails, and the bus queue outgoing messages are 0 (zero).
I've read that some properties need to be set:
message.ContentType = "application/json";
message.ContentEncoding = "utf-8";
but I don't understand where to enter that.
/If any other solution is possible - please let me know.
If any other information is needed, please let me know.
Thank you
Azure Service Bus
Azure Service Bus
An Azure service that provides cloud messaging as a service and hybrid integration.
542 questions
Azure IoT Hub
Azure IoT Hub
An Azure service that enables bidirectional communication between internet of things (IoT) devices and applications.
1,112 questions
  1. Sander van de Velde 28,161 Reputation points MVP
    2022-10-25T21:12:00.377+00:00
    Hello @TITAN ,
    the Azure IoT Hub supports routing messages to one or more endpoints.
    You can add a condition so based on either message properties or the message body.
    The properties (both system properties and application properties) are key/value pairs in property bags so these are easy to process for the IoT Hub.
    The body is not that simple though.
    The body arrives as a byte array and needs to be 'decoded' first.
    Microsoft has decided to support only body messages written in JSON and encoded in UTF-8.
    You have to add this to each message sent.
    If you are using one of the Azure IoT Device SDKs, the class properties are available for you:
    using (var message = new Message(messageBytes))
        await deviceClient.SendEventAsync(message);
    As far as I know, this is also supported for non-SDK device connectivity solutions.
    If you fail to add these, your route will not be triggered.
    Personally, I would limit IoT Hub routing to no-functional routing because there is a limit to the number of routes and endpoints offered. I recommend using a Stream Analytics job to actually filter/route messages based on business rules.
    If the response helped, do "Accept Answer". If it doesn't work, please let us know the progress. By doing so, all community members who have a similar issue will benefit. Your contribution is highly appreciated.
