@Mohammed Anzal , Welcome to the Microsoft Q&A forum.
Based on my understanding of your question above you have enabled compression on Azure Front Door and you have observed that few files are not compressed and file size is 1.4 MB.
This scenario can happen if compression isn't enabled for the requested file type. From the documentation here, you can check if this particular file type is added to the Compressed file types list. You can modify the default list of MIME types on Optimizations page.
Another troubleshooting step you can try in this case is to see if the file is compressed if compression is enabled at origin itself. This will help us understand if the issue is due to Azure Front Door or due to some other component.
Additional reference - https://learn.microsoft.com/en-us/azure/frontdoor/standard-premium/troubleshoot-compression
Hope this helps! Please let me know if you have any additional questions. Thank you!
