Failover Cluster Hyper-V and problems with CSVs - Windows Server 2019
drClays 146 Reputation points
2022-11-21T09:42:14.963+00:00
I have got a 2-node failover cluster on Windows Server 2019.
I have shared 3 CSVs on these nodes.
The cluster is "working correctly" when I have all my VMs on one node, but when I try to migrate some VMs on the second node I have got problems because this node "dies" and stops VMs.
One VM can be on the second node others cannot.
That's what I have when I try to migrate VMs between nodes:
It's a network issue?
Windows Server 2019
Windows Server 2019
A Microsoft server operating system that supports enterprise-level management updated to data storage.
3,437 questions
Hyper-V
Hyper-V
A Windows technology providing a hypervisor-based virtualization solution enabling customers to consolidate workloads onto a single server.
2,526 questions
Windows Server Clustering
Windows Server: A family of Microsoft server operating systems that support enterprise-level management, data storage, applications, and communications.Clustering: The grouping of multiple servers in a way that allows them to appear to be a single unit to client computers on a network. Clustering is a means of increasing network capacity, providing live backup in case one of the servers fails, and improving data security.
953 questions
  1. Michael Durkan 12,146 Reputation points MVP
    2022-11-21T09:51:48.287+00:00
    Hi
    can you run "Validate Cluster" to run a report against the cluster health? This will show any issues that exist and will pinpoint any issues that exist on the second node
    https://learn.microsoft.com/en-us/previous-versions/windows/it-pro/windows-server-2012-r2-and-2012/jj134244(v=ws.11)
    Thanks
    Michael Durkan
    • If the reply was helpful please upvote and/or accept as answer as this helps others in the community with similar questions. Thanks!
  2. Alex Bykovskyi 1,681 Reputation points
    2022-11-24T20:29:43.953+00:00
    Hello,
    As mentioned, try to run validation on your cluster and check if report contains any errors. In addition, the following article might help with troubleshooting:
    https://learn.microsoft.com/en-us/troubleshoot/windows-server/backup-and-storage/event-5120-5142-access-clusterstorage-folder
    What are you using as a shared storage? There might be an issue with your network configuration. The following articles might be helpful:
    https://techcommunity.microsoft.com/t5/failover-clustering/failover-clustering-networking-basics-and-fundamentals/ba-p/1706005
    https://www.starwindsoftware.com/best-practices/starwind-virtual-san-best-practices/
    Cheers,
    Alex Bykovskyi
    StarWind Software
