Help with T-SQL problem
RogerBinny1234 41 Reputation points
2021-01-28T22:55:15.17+00:00
I have a scenario for which I am struggling to come up with a query.
We get some tickets logged every day by different users. Every time a user logs a ticket we create a new ticket reference for it. Once the ticket resolves we mark it as completed but if the user is not satisfied he/she can re-open the same ticket.
We have to readdress the issue and mark the ticket as completed. The user might accept it or re-open it again for further investigation. This cycle will continue.
So basically a ticket gets closed reopened N number of times.
We log all this information in 3 tables.
Table 1 --> Tickets (TicketID Int, TicketType Varchar, TIcketLoggedDate DateTime, UserID INT)
Table 2 --> ClosedTickets (TicketID INT, ClosedTime DateTime)
Table 3 --> ReOpenedTickets (TicketID INT, ReOpenedTime DateTime)
Let's say the data looks like this.
Ticket Close Table looks similar to this
Ticket ReOpenTable look something similar to this
Now I want to generate a report using these 3 tables to show all the tickets whether they are currently open or closed. Also the history of ticket closures/reopens
So I need to write a query which should give me this result.
Hope the result set is self-explanatory.
I tried different types of queries but I am not able to get the output. Could someone please assist?
Thanks in advance.
-Roger
Azure SQL Database
SQL Server
SQL Server
A family of Microsoft relational database management and analysis systems for e-commerce, line-of-business, and data warehousing solutions.
12,601 questions
SQL Server Integration Services
A Microsoft platform for building enterprise-level data integration and data transformations solutions.
2,449 questions
Transact-SQL
Transact-SQL
A Microsoft extension to the ANSI SQL language that includes procedural programming, local variables, and various support functions.
4,544 questions
  1. MelissaMa-MSFT 24,176 Reputation points
    2021-01-29T09:15:05.877+00:00
    Hi @MJ-4179,
    Please refer below updated one:
    drop table if exists Tickets,ClosedTickets,ReOpenedTickets
    create table Tickets
    (TicketID Int, TicketType Varchar(20), TIcketLoggedDate DateTime, UserID INT)
    insert into  Tickets values
    (1,'Incident','01/01/2020 19:33:00',1000),
    (2,'Incident','01/13/2020 18:23:00',1000),
    (3,'Incident','01/15/2020 22:33:00',1000),
    (4,'SR','01/01/2020 13:33:00',1000),
    (5,'Incident','02/02/2020 09:33:00',2000),
    (6,'Incident','01/22/2020 11:33:00',3000),
    (7,'Major','01/21/2020 00:33:00',4000)
    create table ClosedTickets
    insert into  ClosedTickets values
    (1,'01/12/2020 00:00'),
    (4,'01/19/2020 00:00'),
    (1,'01/15/2020 08:30'),
    (1,'01/13/2020 10:11'),
    (1,'01/12/2020 08:33')
    create table ReOpenedTickets
    insert into  ReOpenedTickets values
    (1,'01/13/2020 13:11'),
    (1,'01/16/2020 22:11'),
    (7,'01/23/2020 18:16')
    ;with cte as (
    select TicketID,TicketType,TIcketLoggedDate from Tickets
    union all
    select b.TicketID,a.TicketType,min(b.ClosedTime) ClosedTime from  Tickets a
    inner join ClosedTickets b on a.TicketID=b.TicketID
    left join (select *,lag(ReOpenedTime) over (PARTITION BY TicketID ORDER BY ReOpenedTime) ReOpenedTimepre
    from ReOpenedTickets) c on b.TicketID=c.TicketID
    where (b.ClosedTime<c.ReOpenedTime and (b.ClosedTime>c.ReOpenedTimepre or c.ReOpenedTimepre is null)) or c.ReOpenedTime is null
    group by b.TicketID,a.TicketType,c.ReOpenedTime
    union all
    select a.TicketID,a.TicketType,b.ReOpenedTime  from Tickets a
    inner join ReOpenedTickets b on a.TicketID=b.TicketID
    where exists (select 1 from ClosedTickets where TicketID=b.TicketID)
    ,cte1 as (
    select *,ROW_NUMBER() OVER(PARTITION BY TicketID ORDER BY TIcketLoggedDate) rn from cte )
    ,a.TIcketLoggedDate,b.TIcketLoggedDate TicketClosedDate
    ,case when b.TIcketLoggedDate is null then 'Open' else 'Closed' end CuurentStatus
    from cte1 a left join cte1 b
    on a.TicketID=b.TicketID and a.rn = b.rn -1 and b.rn % 2 = 0
    where a.rn % 2 =1
    Best regards
    Melissa
2 additional answers
    2021-01-29T03:02:01.62+00:00
    Hi @MJ-4179,
    Welcome to Microsoft Q&A!
    Please refer below:
     ;with cte as (
     union all
     select a.TicketID,a.TicketType,b.closedtime from Tickets a
     union all
     ,cte1 as (
     where a.rn % 2 =1
    Output:
    TicketID TicketType TIcketLoggedDate TicketClosedDate CuurentStatus
    1 Incident 2020-01-01 19:33:00.000 2020-01-12 00:00:00.000 Closed
    1 Incident 2020-01-13 13:11:00.000 2020-01-15 08:30:00.000 Closed
    1 Incident 2020-01-16 22:11:00.000 NULL Open
    2 Incident 2020-01-13 18:23:00.000 NULL Open
    3 Incident 2020-01-15 22:33:00.000 NULL Open
    4 SR 2020-01-01 13:33:00.000 2020-01-19 00:00:00.000 Closed
    5 Incident 2020-02-02 09:33:00.000 NULL Open
    6 Incident 2020-01-22 11:33:00.000 NULL Open
    7 Major 2020-01-21 00:33:00.000 NULL Open
    Best regards
    Melissa
  2. RogerBinny1234 41 Reputation points
    2021-01-29T08:21:31.017+00:00
    Thanks, Melissa,
    It worked, but there's a slight challenge.
    It's actually a data quality issue we have.
    We might sometimes get a few bogus entries in both ClosedTickets table as well as ReOpenedTickets table (we don't currently have bogus entries in the latter table yet but we might get them).
    Those yellow highlighted records in ClosedTickets table are incorrect records. They got closed multiple times without the ticket being reOpened. Whenever this happens we should pick the minimum closedTime of the closed tickets until it got reOpened.
    Similarly, there's one more possibility that a ticket might get ReOpened without it being closed. We should ignore them.
    Sorry, I didn't like the system design but it what it is.
    So the Output I require is the same as my original request.
    Thank you for your help.
    Regards,
    -Roger
