Spark Dataframe writing issue in azure from spark: One of the request inputs is not valid
Abdul Hafiz A.G A ID(RITM0203509) 11 Reputation points
2022-08-25T04:24:33.64+00:00
I am able to read data from azure blob storage but when writing back to azure storage then it throws below error . I am running this program in my local machine. Can someone help me out on this please.
Program
val config = new SparkConf();
val spark = SparkSession.builder().appName("AzureConnector ").config(config).master("local[*]").getOrCreate()
try {
spark.sparkContext.hadoopConfiguration.set("fs.azure", "org.apache.hadoop.fs.azure.NativeAzureFileSystem")
spark.sparkContext.hadoopConfiguration.set("fs.wasbs.impl", "org.apache.hadoop.fs.azure.NativeAzureFileSystem")
spark.sparkContext.hadoopConfiguration.set("fs.azure.account.key.myaccount.blob.core.windows.net",
"mykey")
val csvDf = spark.read.csv("wasbs://workspaces@sundareshwaran .blob.core.windows.net/test/test.csv")
csvDf.show()
csvDf.coalesce(1).write.format("csv").mode("overwrite").save("wasbs://workspaces@sundareshwaran .blob.core.windows.net/test/output")
} catch {
case e: Exception => {
e.printStackTrace()
Error:
org.apache.hadoop.fs.azure.AzureException: com.microsoft.azure.storage.StorageException: One of the request inputs is not valid. at org.apache.hadoop.fs.azure.AzureNativeFileSystemStore.rename(AzureNativeFileSystemStore.java:2482) at org.apache.hadoop.fs.azure.NativeAzureFileSystem$FolderRenamePending.execute(NativeAzureFileSystem.java:424) at org.apache.hadoop.fs.azure.NativeAzureFileSystem.rename(NativeAzureFileSystem.java:1997) at org.apache.hadoop.mapreduce.lib.output.FileOutputCommitter.commitTask(FileOutputCommitter.java:435) at org.apache.hadoop.mapreduce.lib.output.FileOutputCommitter.commitTask(FileOutputCommitter.java:415) at org.apache.spark.mapred.SparkHadoopMapRedUtil$.performCommit$1(SparkHadoopMapRedUtil.scala:50) at org.apache.spark.mapred.SparkHadoopMapRedUtil$.commitTask(SparkHadoopMapRedUtil.scala:76) at org.apache.spark.internal.io.HadoopMapReduceCommitProtocol.commitTask(HadoopMapReduceCommitProtocol.scala:153) at org.apache.spark.sql.execution.datasources.FileFormatWriter$$anonfun$org$apache$spark$sql$execution$datasources$FileFormatWriter$$executeTask$3.apply(FileFormatWriter.scala:260) at org.apache.spark.sql.execution.datasources.FileFormatWriter$$anonfun$org$apache$spark$sql$execution$datasources$FileFormatWriter$$executeTask$3.apply(FileFormatWriter.scala:256) at org.apache.spark.util.Utils$.tryWithSafeFinallyAndFailureCallbacks(Utils.scala:1375) at org.apache.spark.sql.execution.datasources.FileFormatWriter$.org$apache$spark$sql$execution$datasources$FileFormatWriter$$executeTask(FileFormatWriter.scala:261) at org.apache.spark.sql.execution.datasources.FileFormatWriter$$anonfun$write$1$$anonfun$apply$mcV$sp$1.apply(FileFormatWriter.scala:191) at org.apache.spark.sql.execution.datasources.FileFormatWriter$$anonfun$write$1$$anonfun$apply$mcV$sp$1.apply(FileFormatWriter.scala:190) at org.apache.spark.scheduler.ResultTask.runTask(ResultTask.scala:87) at org.apache.spark.scheduler.Task.run(Task.scala:108) at org.apache.spark.executor.Executor$TaskRunner.run(Executor.scala:335) at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) at java.lang.Thread.run(Thread.java:748) Caused by: com.microsoft.azure.storage.StorageException: One of the request inputs is not valid. at com.microsoft.azure.storage.StorageException.translateException(StorageException.java:162) at com.microsoft.azure.storage.core.StorageRequest.materializeException(StorageRequest.java:307) at com.microsoft.azure.storage.core.ExecutionEngine.executeWithRetry(ExecutionEngine.java:177) at com.microsoft.azure.storage.blob.CloudBlob.startCopyFromBlob(CloudBlob.java:764) at org.apache.hadoop.fs.azure.StorageInterfaceImpl$CloudBlobWrapperImpl.startCopyFromBlob(StorageInterfaceImpl.java:399) at org.apache.hadoop.fs.azure.AzureNativeFileSystemStore.rename(AzureNativeFileSystemStore.java:2449) ... 19 more
Azure HDInsight
Azure HDInsight
An Azure managed cluster service for open-source analytics.
198 questions
Azure Databricks
Azure Databricks
An Apache Spark-based analytics platform optimized for Azure.
1,916 questions
  1. Vinodh247-1375 11,046 Reputation points
    2022-08-25T05:32:30.39+00:00
    Hi AbdulHafiz,
    Thanks for reaching out to Microsoft Q&A.
    If the credentials are at fault you wont be able to both read/write but since you say you are able to read, can you double check if the location where you are trying to write is correct?
    Please Upvote and Accept as answer if the reply was helpful.
  2. Junjie Cao 1 Reputation point Microsoft Employee
    2022-09-14T00:02:23.46+00:00
    @Abdul Hafiz A.G A ID(RITM0203509) did you try to use 'abfss' instead of 'wasbs'?
