Tap Problem with Right Side of Touchpad
2017-06-29T21:29:28+00:00
Microsoft Surface devices are driving me nuts.  I had a Surface Book that had this same issue that was eventually, after almost a year, fixed, but now that I've been given a new Surface Pro 4 for work I'm back to the same problem again.
At random times, the right half of the Touchpad will stop responding to taps (not clicks).  So, for example, when you're trying to move the cursor to a particular spot in Microsoft Word, you slide the cursor to where you want to be and then tap with your finger to put the insertion point there.  The problem is that frequently, the insertion point won't move.  When this occurs, sliding your finger around to move the cursor works just fine, but taps on the right half of the Touchpad do nothing.  If you then reach your finger over to anywhere on the left side of the Touchpad and tap, it works.
As people found earlier on the Surface Book, if you go into the Touchpad settings and set the delay to, 'None - always on' then the Touchpad will work and not experience this problem, but that's no solution as then when you're typing, you frequently get the cursor jumping around when you accidentally brush the Touchpad with a finger or palm.
I have verified that all Touchpad (and other) drivers are up-to-date and had to manually install some to get them up to the current revision, but this has not solved the problem and this is an extremely disrupting and annoying bug that happens frequently and really destroys my workflow.
Does anyone have any new ideas or suggestions for troubleshooting and eliminating this problem?
Thanks for any assistance that you can provide!
Surface | Accessories | Surface mice and keyboards
2017-10-17T23:17:12+00:00
We appreciate the update. You can use a different browser to check if it will go through. If you're still unable to reach our Answer Desk team using this link, you can give them a call instead. Get the number you can dial by opening this page.
Let us know if you have other questions.
11 additional answers
    2017-10-03T16:53:56+00:00
    I wanted to raise this issue again as it is still occurring and we desperately need a fix!!!
    The right half of the Touchpad will randomly stop registering taps.  The only way to fix it is to either tap on the left half of the Touchpad to get it to register or push forcefully on the right side to trigger the switch in the Touchpad.  This has been an ongoing problem for years now with the Touchpads in all of the Surface devices and Microsoft really needs to look into this.  No amount of resetting or reinstalling Windows or messing with updates has any effect on the problem.  It is inherent in the current Touchpad drivers.  I can easily replicate it across multiple keyboards and Surfaces.
    The only fix that I've found is to, in the previous versions of Windows 10, turn off the feature that allows for a delay on Touchpad response when typing.  Turn this feature off, and the Touchpad always registers taps on the Touchpad no matter where they are initiated.  Disabling this feature, though, comes with a host of other problems if you accidentally touch or brush the Touchpad while typing.  Ugh!
    After the Creator's Update, the feature is now called Touchpad sensitivity.  The only way to get taps to successfully register all of the time is to select 'Most sensitive'.  Then it will work as it should and will always register all taps no matter where they are initiated on the Touchpad.  However, this too presents a host of other problems because the Touchpad is now too sensitive to work well.  For example, if you're trying to do a two-finger scroll, if you don't touch both fingers down at precisely the same moment, you just wind up zipping the cursor all over the screen rather than scrolling as you were intending to do.
    I can't believe that a fully functioning Touchpad driver is so difficult to create.  Other companies, including the Surface family's primary competitor, that fruit company can do it, so why can't Microsoft get it together and fix theirs.
    This is a huge productivity killer and it is irritating beyond belief!  You cannot get into any kind of a working rhythm because you're either running into other issues because the sensitivity is too high or you are missing taps because you're on one of the other settings.
    It's also extremely infuriating that a bug that has been widely reported on the Internet and directly to Microsoft via their technical support group and forums still exists after several YEARS!  I swear that one of these days I'm going to lose it and my Surface Pro 4 is going to wind up smashed to bits!
    Microsoft, please, please, please look into this and fix this bug!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    2017-10-07T03:10:09+00:00
    I have manually installed updated drivers with every new release to no effect.  All drivers related to the Touchpad, and the rest, too, by the way, have all been manually verfied to ensure that they are up to date all to no avail.  I have spent countless hours on trying to resolve this, but the problem remains.
    Please hook me up with an engineer to look into this problem.  I can demonstrate it pretty much at will by simply changing the Touchpad sensitivity.  If I do this and tap around for a minute or two, the Touchpad will always stop recognizing taps on the right half of the pad.  Then, no amount of tapping will get it to recognize a tap on the right side unless you either push hard enough to activate the mechanical switch or tap on the left half of the pad.  Once either of those actions have occurred, the right side will again accept taps for a while until the whole cycle starts over again.
    I have been put in contact with Microsoft engineers via this forum before and have worked with them to resolve issues (well, some issues got resolved, but some, unfortunately, were unable to be fixed) and would really like to go this route again, if possible.  I don’t think there are any other options remaining at this point.
    2017-10-04T02:42:32+00:00
    No, none of these suggestions make any difference, including resetting (re-imaging) the system.  This is clearly a driver problem that needs to be fixed.
    2017-07-14T23:48:43+00:00
    We know that you've done multiple troubleshooting already in an attempt to fix your touch pad issue. Checking the touch pad settings, running the Software Repair Tool and making sure the connectors are looking good, those are good troubleshooting. Great job on that!
    However, since the touch pad is still failing to recognize your intended taps, and still having the same issues, we would suggest for you to check this troubleshooting:
    1. Shut down the Surface.
    2. Hold down the Volume UP and Power Button simultaneously for 10 seconds.
    3. Power on the Surface (if it goes into the BIOS screen, you need to tap on Exit setup).
    4. The Surface will boot up and check if the problem is still evident.
    If the above steps won't work, then you may need to perform **reset**on your Surface to rule out any software issues. Just a friendly reminder, you need to back up your files before doing a reset.
    Feel free to post back if you need more help.
