Hi, good morning.
I have developed a IoT Edge solution that allows sending messages in batches to IoT Hub. Instead of sending single json messges, I'm sending a Json array in order to reduce sending IoT Hub message number due to costs. All is working fine, and messages are arriving correctly in the IoT Hub.
But when I try to ingest these messages directly in Azure Data Explorer using IoT Hub Data Connection, I've a problem mapping Event System Properties to the messages.
As I'm using MULTIJSON format, each single message in the array is processed correctly, but the Event System Properties, for example the DeviceId, are only being mapped to a single message in the batch.
Is there a way to map these properties to all messages in the json array before storing them in ADX table.
Thank you very much.
Best regards.
