<3> 2022-11-10 09:54:40.149 +00:00 [ERR] [EdgeHub] - Stopping with exception
System.UnauthorizedAccessException: Access to the path '/tmp/edgeHub/DEVICE_IDENTITY.json' is denied.
---> System.IO.IOException: Permission denied
--- End of inner exception stack trace ---
at Interop.ThrowExceptionForIoErrno(ErrorInfo errorInfo, String path, Boolean isDirectory, Func`2 errorRewriter)
at Microsoft.Win32.SafeHandles.SafeFileHandle.Open(String path, OpenFlags flags, Int32 mode)
at System.IO.FileStream.OpenHandle(FileMode mode, FileShare share, FileOptions options)
at System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share, Int32 bufferSize, FileOptions options)
at System.IO.StreamWriter.ValidateArgsAndOpenPath(String path, Boolean append, Encoding encoding, Int32 bufferSize)
at System.IO.StreamWriter..ctor(String path)
at System.IO.File.WriteAllText(String path, String contents)
at Microsoft.Azure.Devices.Edge.Util.PersistentStorageValidation.ValidateStorageIdentity(String storagePath, String deviceId, String iotHubHostname, String moduleId, Option`1 moduleGenerationId, ILogger logger) in /mnt/vss/_work/1/s/edge-util/src/Microsoft.Azure.Devices.Edge.Util/PersistentStorageValidation.cs:line 20
at Microsoft.Azure.Devices.Edge.Hub.Service.DependencyManager.GetStoreAndForwardConfiguration() in /mnt/vss/_work/1/s/edge-hub/core/src/Microsoft.Azure.Devices.Edge.Hub.Service/DependencyManager.cs:line 353
at Microsoft.Azure.Devices.Edge.Hub.Service.DependencyManager.Register(ContainerBuilder builder) in /mnt/vss/_work/1/s/edge-hub/core/src/Microsoft.Azure.Devices.Edge.Hub.Service/DependencyManager.cs:line 127
at Microsoft.Azure.Devices.Edge.Hub.Service.Startup.BuildContainer(IServiceCollection services) in /mnt/vss/_work/1/s/edge-hub/core/src/Microsoft.Azure.Devices.Edge.Hub.Service/Startup.cs:line 93
at Microsoft.Azure.Devices.Edge.Hub.Service.Startup.ConfigureServices(IServiceCollection services) in /mnt/vss/_work/1/s/edge-hub/core/src/Microsoft.Azure.Devices.Edge.Hub.Service/Startup.cs:line 45
at Microsoft.AspNetCore.Hosting.WebHost.EnsureApplicationServices()
at Microsoft.AspNetCore.Hosting.WebHost.Initialize()
at Microsoft.AspNetCore.Hosting.WebHostBuilder.Build()
at Microsoft.Azure.Devices.Edge.Hub.Service.Hosting.Initialize(IConfigurationRoot configuration, X509Certificate2 serverCertificate, IDependencyManager dependencyManager, Boolean clientCertAuthEnabled, SslProtocols sslProtocols) in /mnt/vss/_work/1/s/edge-hub/core/src/Microsoft.Azure.Devices.Edge.Hub.Service/Hosting.cs:line 79
at Microsoft.Azure.Devices.Edge.Hub.Service.Program.MainAsync(IConfigurationRoot configuration) in /mnt/vss/_work/1/s/edge-hub/core/src/Microsoft.Azure.Devices.Edge.Hub.Service/Program.cs:line 67
Unhandled exception. System.AggregateException: One or more errors occurred. (Access to the path '/tmp/edgeHub/DEVICE_IDENTITY.json' is denied.)
---> System.UnauthorizedAccessException: Access to the path '/tmp/edgeHub/DEVICE_IDENTITY.json' is denied.
at System.Threading.Tasks.Task`1.GetResultCore(Boolean waitCompletionNotification)
at System.Threading.Tasks.Task`1.get_Result()
at Microsoft.Azure.Devices.Edge.Hub.Service.Program.Main() in /mnt/vss/_work/1/s/edge-hub/core/src/Microsoft.Azure.Devices.Edge.Hub.Service/Program.cs:line 36
[2mNov 10 09:54:41.294 [0m [32m INFO [0m watchdog::child: Edge Hub process has stopped
in my azure iot edge vm, edgeHub module can not access mounted volume
/data/edgeHub/ directory in system is mounted to /tmp/edgeHub directory in contianer
/data/ directory in system is mounted with a separated azure disk
looks like edgeHub container has to permission to access mounted directory
any help?
