No response from classification service
HTTPConnectionPool(host='testclassifier', port=80): Max retries exceeded with url: /image (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x7f7a7588d0>: Failed to establish a new connection: [Errno 111] Connection refused'))
Connectivity checks
√ host can connect to and perform TLS handshake with IoT Hub AMQP port
√ host can connect to and perform TLS handshake with IoT Hub HTTPS port
√ host can connect to and perform TLS handshake with IoT Hub MQTT port
√ container on the default network can connect to IoT Hub AMQP port
√ container on the default network can connect to IoT Hub HTTPS port
√ container on the default network can connect to IoT Hub MQTT port
√ container on the IoT Edge module network can connect to IoT Hub AMQP port
√ container on the IoT Edge module network can connect to IoT Hub HTTPS port
√ container on the IoT Edge module network can connect to IoT Hub MQTT port
√ Edge Hub can bind to ports on host
No errors are showing up when I do iotedge check
The ports which are listening on the IoT edge jetson nano
How do I resolve this error?
