Not Monitored
Tag not monitored by Microsoft.
36,262 questions
This browser is no longer supported.
Upgrade to Microsoft Edge to take advantage of the latest features, security updates, and technical support.
Hello,
I'm trying to understand why a few of our machines show very different "Memory available" metrics between the amount shown in "Virtual Machine host" and "Guest (classic)"
For example:
Virtual Machine Host - "Available Memory Bytes (preview)" avg shows available memory can dip to 200MB.
But Guest classic - "Memory available" avg over the same period is showing that the VM never dips below 10GB.
Its a Linux VM.
Can anyone explain why this is, and which metric I should be using as the one to look at?
Thanks
