Deleting unused parts of disk
Denis_343 21 Reputation points
2022-05-10T12:41:40.113+00:00
Hello, i updated win10 to win11 and i used it for a couple of weeks, it was time to dust my pc(unplugged only the cables), after cleaning i got BSoD(it was error kinda "efi bootloader"), fixed it. After i checked disk manager and saw 2 unused parts of disk, tried to delete it from there and using other software, but unsuccessfully. Can you help to solve this problem?200587-kcjk234sdfstw4t.jpg
Windows 11
Windows 11
A Microsoft operating system designed for productivity, creativity, and ease of use.
8,455 questions
  1. Docs 15,226 Reputation points
    2022-05-12T15:54:26.407+00:00
    The 763 MB of unallocated space (10 + 753) can be used.
    In order to use it the partitions need to moved.
    This can be accomplished with third party software.
    (MiniTool partition wizard, Disk Genius, etc.)
    https://www.lifewire.com/free-disk-partition-software-tools-2624950
    Disk Management often does not display all partitions on a disk drive.
    (the hidden partitions are not seen)
    Normally a GPT partition has 4 default partitions.
    The reserved partition is hidden and typically not seen in disk management.
    The recovery partition is missing and was likely the 753 MB partition.
    If you use a bootable Media Creation Tool MCT (windows 10 iso) or if you routinely make backup images then you can do without a recovery partition.
    However it is handy when there are Windows problems, for example, failure to boot.
    See Partition Layout:
    https://learn.microsoft.com/en-us/windows-hardware/manufacture/desktop/configure-uefigpt-based-hard-drive-partitions?view=windows-11
    In order to see the hidden partitions open administrative command prompt and copy and paste (all at one time):
    diskpart
    lis dis
    det dis
    lis vol
    lis par
    sel par 1
    det par
    sel par 2
    det par
    sel par 3
    det par
    sel par 4
    det par
    sel par 5
    det par
    sel dis 1
    det dis
    lis par
    sel par 1
    det par
    sel par 2
    det par
    Please remember to vote and to mark the replies as answers if they help.
    On the bottom of each post there is:
    Propose as answer = answered the question
    On the left side of each post there is /\ with a number: click = a helpful post
2 additional answers
  1. S.Sengupta 15,841 Reputation points MVP
    2022-05-11T16:20:40.127+00:00
  2. Docs 15,226 Reputation points
    2022-05-12T04:03:18.297+00:00
    The computer has unallocated space.
    There is nothing to delete in unallocated space.
    The maximum space that can be used is less than 1 GB.
    The 763 MB may be able to be used however in almost all cases it is not worth the time and effort.
