See:
How to fix num lock notification setting
Recently, my num lock on/off notification appeared on the screen for a few seconds but is not showing on the screen. How to enable it again? However, the key function is working on the keyboard.
Karlie Weng 19,131 Reputation points Microsoft Vendor
2024-11-26T01:53:41.9233333+00:00 Hello,
You can try to set the registry
1.Open the Registry Editor:
Press Win + R to open the Run dialog box.
2.Navigate to the Registry Key:
Go to the following path:
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\Indicator
3.Modify the Registry Value:
Inside the Indicator key, look for a DWORD (32-bit) Value named CapsLockIndicator.
Set its value to 0 to disable the on-screen notification.
4.Restart Your Computer:
Restart your computer to apply the changes.
