Power BI paginated report on a local Power BI server to publish on Share Point online
Sedso 1 Reputation point
2020-08-04T09:16:38.153+00:00
I have a paginated report on a local Power BI Server. It works fine.
I want to show this report on a Share Point Online page as a web part. I am getting an error regarding the URL of the report that it is not valid.
All the examples that I have found publishes the reports on the Power BI online. Is there any chance that a paginated report on a local server can be used on a SharePoint online page? If so, how?
Thanks in advance.
SQL Server Reporting Services
A SQL Server technology that supports the creation, management, and delivery of both traditional, paper-oriented reports and interactive, web-based reports.
2,813 questions
  1. Leon Laude 85,666 Reputation points
    2020-08-04T09:27:05.46+00:00
    Power BI is currently not supported in the Q&A forums, the supported products are listed over here https://learn.microsoft.com/en-us/answers/products (more to be added later on).
    You can ask the experts in the dedicated Power BI forum over here:
    https://community.powerbi.com/t5/Forums/ct-p/PBI_Comm_Forums
    (If the reply was helpful please don't forget to accept as answer, thank you)
    Best regards,
    Leon
  2. ZoeHui-MSFT 33,296 Reputation points
    2020-08-05T01:59:02.567+00:00
    There is a way to embed a Power BI Report Server report using an iFrame in SharePoint.
    For your reference:
    https://learn.microsoft.com/en-us/power-bi/report-server/quickstart-embed#embed-the-report-in-a-sharepoint-iframe
    There is also another way to publish a report to a SharePoint library, the example is about SSRS which is similar with PBIRS.
    https://learn.microsoft.com/en-us/sql/reporting-services/reports/publish-a-report-to-a-sharepoint-library?view=sql-server-ver15
  3. ZoeHui-MSFT 33,296 Reputation points
    2020-08-07T06:32:58.497+00:00
    May I know how is the issue going on now?
    If you do not have any other concerns, please remember to mark the answer.
