Power Automate: SQL - Transform Data using Power Query recently started giving AADSTS7000113: Application 'f3b07414-6bf4-46e6-b63f-56941f3f4128' is not authorized to make application on-behalf-of calls error
Waqar Qureshi 40 Reputation points
2024-11-10T19:44:50.0566667+00:00
All my Transform Data Using Power Query steps in my flows are receiving the following message after Friday afternoon. I had some successful runs before that, perhaps 30 minutes prior.
The error I am receiving is the following:
AADSTS7000113: Application 'f3b07414-6bf4-46e6-b63f-56941f3f4128' is not authorized to make application on-behalf-of calls. Trace ID: 27abcedf-d2b9-4f61-a2e3-aecccd0be601 Correlation ID: fa72225e-8007-4254-818c-60484c37d060 Timestamp: 2024-11-10 19:31:50Z
Is this perhaps a limit exceeded? Is there anyway to find out or diagnose this?
I double checked with IT and I have user access to the On-prep gateway that the SQL server works with.
  1. Łukasz Pęsik 0 Reputation points
    2024-11-12T14:39:18.3+00:00
    Hello all think, i have solutions.
    Try this:
    • Log in to the Entra ID portal: Go to the Entra ID portal and log in to your account with the appropriate permissions (Application Administrator or Global Administrator)
    • Find your enterprise application: In the menu on the left, select "Enterprise applications" and find the application for which you want to add a delegated entitlement. You must search this: Application 'f3b07414-6bf4-46e6-b63f-56941f3f4128'
    My sample error log
    "message":"AADSTS7000113: Application 'f3b07414-6bf4-46e6-b63f-56941f3f4128' is not authorized to make application on-behalf-of calls. Trace ID: 99fafe84-cc0b-4fce-97a1-8875b9986d00 Correlation ID: 6d29d354-d4c2-46c1-b7e8-01bbee7873a5 Timestamp: 2024-11-12 14:22:20Z","resultType":"Exception"}}
    • Go to Users and groups and add permissions for the group or user who created the flow.
    Enjoy
